I have seen a few links for converting a Series Rover front diff to 24 spline axles and carriers. But nothing on the rears. Can I just get a 24 spline carrier, new ring and pinion and new axles and drive flanges? Main question is are there any clearance problems with the 24 spline axle diameter, internal to the diff housing?
I was going to get a Salisbury, but not sure (exactly) how much they are going for now and still an open diff. If no issues with axle clearance, I was thinking about just building up a Rover diff with a TruTrac or other limited slip carrier. I figured it would be roughly the same cost as the Salisbury, with new ring and pinion, axles, and a LSD. Have also heard that the replacement ring and pinions are much stronger than the original Rover ones.
Any pros/cons to this? Or other advice?
