Any recommendations, (which and where to get it from) for a spin-on oil filter replacement option for the 6cyl (2.6 NADA 109 engine)? The set up I assume would come with or use the original sending unit connection port, I’m going to put a mechanical gauge unit on it. FYI the Rocky Mountain one won't work as the 6cly has a top bolt attachment point and there's is made for a bottom-up bolt.
Spin on oil filter for 6cyl
I bought one over a decade ago from Robert Davis. He had a few made up special back then I think.
It's the stock aluminum piece with a (stick?) welded aluminum face on the bottom to take a spin on filter. I guess if you have your aluminum bracket and could find an aluminum adapter face someone could weld one up.
(Still have a few of those damn cartridge filters laying around too...)61 II 109" Pickup (Restomod, 350 small block, TR4050)
67 IIA 109" NADA Wagon (sold)
