Originally posted by jp-
You are correct in that to get the pump to prime I need to put a bit of gas down the carb thus 'priming' the carb - my bad!
Basically if there is no gas in the line the engine won't turn the pump fast enough to pump fuel. Putting a bit of gas in the carb gets the truck to run enough to create enough suction to get everything moving. Once there is gas the truck runs like a dream. That of course is the only dream as the dream is surrounded by other nightmares like no power steering, iffy brakes (getting fixed this week) a bad side gas tank that will be replaced, horn? what horn?
I may have a leak somewhere up around the carb but I have never seen or smelt it. Of course it might be covered by the continuing problem I have had with the side tank. Either way, my driveway points downhill and the truck is used for Lumber runs or when I need to carry a bunch of crap so I deal with its 'foibles'.
