Series III Compression Ratio
  • edscripps
    • Oct 2007
    • 4
    I would like to verify the compression ratio on my '74 series III, the engine number which begins with 904 indicates it's 7:1, but I was told the best way to confirm was to look on the cylinder head and the compression ratio is stamped on the side. Does anyone know where? I can't seem to find anything that looks like #:#.
    Thanks,
    -Ed
  • rover_chump
    RN Veteran
    • Jun 2006
    • 53
    Greetings,
    Look on the top of the head, between the carb and the manifold (you should see a square block ... about 1" x 1" ...if it is an 8:1 it will have an "8" stamped into that block...you may have to wipe away some grease to see it, sometimes it is stamped lightly. If it is a 7:1 it will have a "7" stamped in the block..or...the block may not even be there)
    If it is the original head....I would assume that its 8:1
    Head thickness.... 7:1 = 3.69" 8:1 = 3.59"
    Peace,
    Art
    Philippians 4:6
    • LH Drive
      • 253
      My series 3 has the 8:1 head and the stamped 8 looks more like two zeros side by side.
      1972 NAS Series 88 SW
      • Leslie
        • 613
        I thought that by the SIII, they were all 8:1; my '72 is an 8....
        On mine, the 8 looks more like gull-wings, as if the 8 were only stamped on one side....
        -L
        '72 SIII SW 88"
        '60 SII 88" RHD
