NADA motor and transmission mounts
  • Armordave
    • Aug 2016
    • 58
    Question: are NADA (2.6cyl) motor mounts different than other Series/motors mounts? what is the correct P/N? In my research (on our host site) I can't find a specific one identified for the 2.6 cyl
    Are the transmission mounts all the same (2.25 and 6 cyl models)? My research seems to show that these are all the same.
  • clearcut
    • Jul 2014
    • 233
    they are the same, but I have been using
    Engine Mounts S3 Diesel
    josh
    1967 Land Rover 109
    1966 Land Rover 109
    Joshua Tyler
    • Armordave
      • Aug 2016
      • 58
      is that the RNE400 part shown on Rovers North site? They are rectangular, mine are round?
      • clearcut
        • Jul 2014
        • 233
        yes
        1967 Land Rover 109
        1966 Land Rover 109
        Joshua Tyler
        • desullivan
          • Aug 2012
          • 27
          I also ordered the motor and trans mounts on RN. Asked the same question since the diameter of the replacement mounts is slightly smaller than the original motor mounts. RN recommended trying the 2.5L motor mounts if I was concerned as the diameter is a bit larger than the original however they will not fit the frame mounts on the left side.
          1967 Series 2A 109 NADA w/2.6l
          • Armordave
            • Aug 2016
            • 58
            I bought the S3 diesel mounts (same for motor and trans)they are the square ones not the round ones; will install them this weekend and report on the results.
