Can anyone offer advice on what parts are used to seal the connection between the waterpump and the head on a 2.6 cyl. If you know the part numbers that would help to. RN is not showing parts for the 2.6 waterpump. I came up with these numbers from my NADA parts book. See if you think they are correct or not. And whom should I check with for these parts.
Main pump to block gasket: 503629 (Joint washer)
Rubber Seal Pump to Cylinder head 09170
Adaptor for Thermostat bypass (1/4 BSP) 515946
