Slight miss - 2.25 Series 3
  • gregseitl
    • May 2018
    • 2
    Hey all,
    Brought the Rover in for a tune up after a .... long.. break from her. I’ve replaced the following with new parts;
    Carb and filter
    points
    condensor ( 1st new one was bad.. that was fun figuring out )
    rotor button and cap
    plugs
    wires
    fuel pump
    spin on oil filter conversion
    I also adjusted the valves to the recommended .010 (cold, however I’m told it’s best hot)
    She runs great however every 3 seconds it putts from the exhaust and at high RPM you can still hear that putt. It’s almost like it has a bit of a miss. I’ve rechecked the points and plugs and am confident I’ve tried every degree on the disty but this silly annoyance won’t go away. Any thoughts or suggestions would be appreciated !
  • lumpydog
    • May 2014
    • 383
    Sometimes if the distributor wires are touching each other, they can bridge and cause this.
    1968 Series IIa
