Hi everyone, This is my 4th summer as a Rover owner and I've had some issues with vapor lock before but this seems different. In the past I put some reflective insulation on my fuel line and all was fixed, no more stalling or hard starting. But the hard starting is back, after I shut the truck off for 5 mins or more on a warm day it takes a good 7-10 seconds of cranking to start the engine. I assumed all the gas was boiling out of the carb and the cranking was filling a dry carb but the engine actually behaves like it's flooded. It won't start unless I hold the throttle wide open and then it spits out a ton of dark, rich exhaust when it turns over. I looked down into the intake and can see there is gas coming from the accelerator pump when I open the throttle manually so that tells me there is gas in the bowl. My theory is that the heat causes the gas to boil, building pressure and forcing the liquid into the the intake ( I can see the gas dripping) this floods engine and once the bowl is empty, fresh gas from the line fills it up and the process continues until the carb cools enough. There are also gas stains all over the intake manifold, which has never happened before this summer. See Pics
I rebuild the carb and re-routed the fuel line to run along the bulkhead instead of directly over the engine. This seems to have helped a little bit but I'm still having a problem. I've been told to install an electric fuel pump but this isn't going to solve the problem, it's just going to mask it. I also thought of buying an in-line fuel filter with a vapor return and running a line back to the tank but I don't think this will help much as I believe the problem is the hot carb.
Has anyone out there fabricated a heat shield to sit just below the carb? Does anyone else have a similar problem or any ideas??
Thanks!
Thanks!
