Directional signal won't blink on one side
  • IIA
    • Apr 2010
    • 158
    The directional signal/turn signal on the left side of my IIA won't flash/blink. The right side works normally and, when I turn the hazard lights, on all four blink normally. I replaced the flasher unit about a year ago. Any ideas what could be the problem?
    1970 Series IIA
    1964 Series IIA [sold]
  • caperover
    • Jan 2012
    • 33
    Check your grounds.
    I had a similar issue after removing the front wings, cleaning, painting, and reassembling.
    After chasing things down with a volt/ohm meter, I finally ran a ground wire from the wing to the chassis and it fixed the lack of blinker problem.
    • phartnady
      • Jul 2017
      • 6
      Had the same issue, removed the directional lens, noted that one screw holding the assembly had a copper piece that was corroded. Removed screw and used dremel to clean the copper piece, reassembled and worked great. Just my 2 cents. Best, phil
      2003 Corvette Z06
      2013 Range Rover Sport
      1967 Series IIA - For when I don't want to go fast.
