Sorry, this is a bit of a long post…so please bear with me
I have a 1985 Series III (ex-MOD) 109 and, before I commit to any further restoration, I would like to upgrade my 5MB, 2.25L engine to see if I can get more top end speed (at lower RPM using an overdrive) without overly compromising the low end torque.
Having now read many web pages and what seems like a thousand forum threads (many of them very good), I know that there are some basic things that can (and have been) done to a 2.25L engine to this end (ie. cam change, CR increase, carburation changes, exhaust modifications, piston over-boring, etc…) and I also know that there are other numerous other engine conversions options that would get me what I am looking for and more. But, the 2.25L engine is the bird I have in hand and I would like to keep things as stock as possible, so I have decided to do what I can with it.
However, before I take the above approach, I would like to get thoughts on the idea of converting my 5MB, 2.25L engine into a 2.5L by:
I have looked at the specs for both the 2.25L and 2.5L engines and, although I am not a seasoned engine builder, it looks to me like it should be possible since I understand (but am not positive) that:
Now, I’ll be the first to agree that this seems like a lot of trouble to go to to get an additional peak 6HP and 9 lbft (difference in peak power and torque for a stock 2.25L and 2.5L engine), but once done I could then apply additional performance upgrades to what would now essentially be a 2.5L engine, namely:
So, my questions are:
Thanks for reading/replying!
- stroking the engine by installing a 2.5L crankshaft, camshaft and pistons, and
- possibly upgrading to 2.5L intake/exhaust manifolds and a 2 bbl carburetor (Weber 34ICH installed now)
- both engines use the same base block
- both engines use the same length connecting rods
- the 2.5L pistons are shorter from crown to gudgeon pin to, I presume, accommodate the additional throw (~5/16”) and maintain head clearance
- the 2.5L pistons are recessed to, I presume, accommodate the additional throw (~5/16”) and maintain an 8:1 CR
- increase CR to 9:1 by milling the head/block
- retard the stock 2.5L cam a bit or install a performance cam (source?)
- port (and maybe polish) the head and manifolds
- up-size and open the exhaust slightly
- Can the proposed base 2.25L to 2.5L conversion be done and what are the primary ‘gotchas’ (either known or anticipated)?
- Assuming the proposed base 2.25L to 2.5L conversion could be done, what else could be (or should not be done) to further improve the performance of the resulting 2.5L engine?
