Hello all,
Happy Labor Day Weekend!
Am trying to finish up my 63 IIa 109 so I can go out and drive it, and am stumped. I need an extra pair of eyeballs to point out the (probably obvious) thing I’m clearly missing.
Due to a cracked head, I tore the engine apart and have rebuilt nearly everything. To be clear this was a running truck, just super down on power due to cracked head.
This truck will have a new lease on life once it actually fires up.
This is a 2.25L petrol with a new 2.5L camshaft, new pistons, new bearings, new everything.
12v negative ground
It was already negative ground before the rebuild
Triple and quadruple (and then some) checked engine timing:
Flywheel pointer at 6deg for 91oct
Distributor rotor pointing at #1 spark plug
New distributor w/ new rotor and condenser
Timed distributor with light, can hear condenser clicking on/off as I rotate distrib body.
Spark plugs new - ngk bp5es - same as I used before
Spark plug wires new (checked resistance across wires, all 2.9~3k ohm)
Spark plug 1 3 4 2 counter clockwise when standing on right side of engine (ie U.K. driver / US pass side)
Fuel pump new - primed carb with hand pump action
Fuel is newish - a couple weeks old now - fuel doesn’t go bad that fast (91)
Carb new rebuilt Rochester - confirmed it squirts gas as it should
New starter
New Autospark UK wire harness with alternator mod
Alternator is a Lucas - worked fine before rebuild
New battery
Coil is 1 year old - same cool I used when it ran last
Tested it has 12v at + lug with key in ignition turned to ON
Negative lug of coil connected to distributor
Checked that I have spark:
Spark plug connected to lead from coil and ground to engine - yes there is a nice spark
Checked each spark plug and wire coming off distributor - pretty faint but there is spark at all 4
Tried a second (brand new) coil
No change
Tried the distributor I had in the truck last time it ran
No change
Tried with choke all the way out and choke all the way in
No change
Ground straps from starter to frame
And from neg battery post to frame and to engine front cover
Starter turns engine freely
With a couple pumps of gas pedal, and/or addition of starting fluid down carb throat all I get are a couple backfires through carb
Rest of electrical functions as it should
Fuel level gauge
Headlights / taillights / turn signals
Horn
All ok
But truck won’t start
What gives?
What am I missing?
Any and all help is appreciated...
Thank you
-e
12v negative ground
New starter
New battery
No change
No change
No change
Fuel level gauge
Horn
All ok
What gives?
What am I missing?
Thank you
-e
