Hi! I’m new to the forum and recently acquired a 1974 88 series 3 project. I’ve gotten stalled early on because the window frames are seized to the door. Any suggestions?????
Seized windows
Mine were rusted in place. Required me to get now door frames and door tops.Sean
1971 Series IIA DormobileComment
I'm having the same problem. I have the drivers side almost off but one post is still not budging. I've used oil, heat, hammer. still not coming off. I'm thinking about using an air hammer chisel. Best of luck!Comment
The only problem I'm aware of is that that the sliding windows don't open as far as stock windows. This may be a problem if you like to rest your elbow on an open window sill.
I tried a set of aftermarket new door tops in '96. The angle was a little off so the door tops did not close tightly against the sides, allowing lots of rain water to enter. By 2010 they were badly rusted to the point that they came off the door bottom in parts. In 2010 I went with genuine LR D90 door tops. Expensive but they are still like new.-
