somethings a bubblin
  • phartnady
    • Jul 2017
    • 6
    on my 67 SIIA, beneath the carb are 4 bolts (fixins) that hold the exhaust manifold to the inlet manifold. I noticed yesterday whilst the truck was parked and at idle, there was a substance bubbling around one of the nuts. i took a wrench and tightened it, and the bubbling stopped. just wondering what that fluid was, seemed oily to the touch. any thoughts from the forum? thanks so much.
    phil
    2003 Corvette Z06
    2013 Range Rover Sport
    1967 Series IIA - For when I don't want to go fast.
  • erik88lr
    • May 2016
    • 126
    Sounds like a witch's brew! Watch out!
    Seriously, if your Landy has a PCV system like my later Series III then it has oil vapors are going into the intake manifold to be burned. I suspect you have some liquid oil diluted by the carb's atomized gas that is oozing out of the bolt holes...
    • phartnady
      • Jul 2017
      • 6
      thank you erik, i appreciate your input.
      phil
      2003 Corvette Z06
