Help Requested: Removing Selectro FWH
  • Myron
    • 96
    Hi guys,
    I'm hoping someone can help me here. I'm trying to remove the Selectro FWH's from my spare axle so I can give them to a friend. They are on the axle from my '64 IIA 88. When I restored the vehicle 16 years ago I used the S3 axles from my donor car. Hence I have a spare pair of IIA axles.
    Question 1: I can't seem to get these off. All the bolts came undone easily and the FWH spins freely with respect to the drive flange, but they don't pull out. What am I missing?
    Question 2: Even if I get them off, will my friend be able to use them on his early Series 3? He has the old MAP hubs that require the tool to lock/unlock and one of them blew up recently so he's looking to get a set of FWH's. I'd like to give him these, but I a wondering about compatibility between SIIA and S3.
    Many thanks!
    Myron
    Pics:
  • erik88lr
    • May 2016
    • 126
    I'd remove the allen headed bolts around the dial ring and see if you don't have a large axle nut to remove.
    • clearcut
      • Jul 2014
      • 233
      Hi
      Does he want sell the one working map hub?
      josh t
      1967 Land Rover 109
      1966 Land Rover 109
      Joshua Tyler
      • Myron
        • 96
        Originally posted by clearcut
        Hi
        josh t
        Thanks @clearcut and @erik88lr! I will try removing the set screws around the outer ring.
        Clearcut, I don't know for sure but I wouldn't be surprised if my buddy would be interested in selling his other working MAP hub. I'll check.
        Thanks again!
        Myron
        • clearcut
          • Jul 2014
          • 233
          Thanks again!
          Myron
          thank you for the update
          josh
          1967 Land Rover 109
          1966 Land Rover 109
          Joshua Tyler
