Universal Fuel Sender
  • bowvmi2001
    • Oct 2019
    • 2
    I purchased an universal fuel sender from our hosts and I am not sure if I assembled it correctly as the fuel gauge reads full when full, but empty when it is at half a tank. The little clips allow the float to spin on the rod that is connected to the sender. So I am not sure if I installed the sender correctly to bring with.
    Is there a way to adjust or a trick to assembling the rod that connects the float to the sender? Any tips would be appreciated.
  • roverp480
    • Jul 2020
    • 335
    It sounds to me that the float arm is not long enough. The full arc of the float should approximate to the depth of the tank.
    • cedryck
      • Sep 2010
      • 836
      Agreed, if you extend the float further down the wire, it should read a little better, always have to start thinking about filling up when my gauge is down around 1/4 anyway, not the most reliable thing out there,
