Backfire and stalling
  • twert1975
    • Mar 2013
    • 21
    I’ve recently starting having a backfire when letting off the gas, mainly in third gear and when I come to a stop it wants to stall. It will idle fine but if you rev the engine and let it return to idle it stalls out. Any ideas where to start? Timing, carb, exhaust?
    1969 series 2a
    2.25 gas
    Electronic ignition
  • cedryck
    • Sep 2010
    • 836
    Check Idle RPM's, is setting screw set to low?
    Timing, is Ignition timing correct?
    Look at filters, are they clear? Does carb have a filter?
    Plugs, are plug gap correct?
    Could be a myriad of items, choose one and follow through.
    • roverp480
      • Jul 2020
      • 335
      Possibly a slight air leak, carb. to manifold or manifold to head.
        • 519
        vacume advance? often though it's vacume leaks.
        • NickDawson
          • Apr 2009
          • 707
          +1 on this post. Think about the engine as a chain. Look at each link in the chain and rule it out.
