Mystery Part Identification
  • RidingDonkeys
    • Sep 2020
    • 28
    I'm troubleshooting a brake failure on a new to me 1964 2a 109 truck and have stumbled across a booster that I cannot identify. Anyone ever seen one of these before?
ID:	174601Click image for larger version
ID:	174602Click image for larger version
  • RidingDonkeys
    • Sep 2020
    • 28
    Sorry for the upside down photos above. They were correctly oriented, but seem to flip every time I upload them.
    • jimrr
      • Dec 2010
      • 489
      i'm certain that is a bleed valve staring us in the face?
      • cedryck
        • Sep 2010
        • 836
        Part of some Power Take off Device?
        • jp-
          • 981
          Bendix Hydrovac remote brake booster.
          67 IIA 109" NADA Wagon (sold)
          • RidingDonkeys
            • Sep 2020
            • 28
            https://www.ebay.com/itm/Vintage-Ben...4383.l4275.c10
            Great catch. That is it and it is still in the hydraulic path. I need to learn a little more about this one.
            • jp-
              • 981
              Most definitely added by a previous owner. Stock one (on the 6cylinders only) was a Lucas Girling unit, that can still be had through Moss Motors. I think the replacement unit is listed for a Jaguar…
              I’ve messed with the Girling stuff extensively and it is very difficult to make them work if you plan to upgrade to front discs at some point. But for an all drum setup they are fine. But an inline booster is the way to go if you want to upgrade and if you ever plan to put disc brakes on the front.
              I don’t know anything about the Bendix unit, but I’d be leery of wasting time on it, unless you ever had it working and actually liked the way it performed.
              • RidingDonkeys
                • Sep 2020
                • 28
                It was actually functioning quite well before the failure. I don't think the Bendix unit is the problem. I found the reservoir pretty low when the problem happened, so I suspect there is a small leak somewhere. I just can't find it. Hopefully I'll have more time this weekend to troubleshoot.
                • RidingDonkeys
                  • Sep 2020
                  • 28
                  Any recommendations for inline boosters? I've since had this thing torn down for restoration and the Bendix is toast. We're at the reassembly phase and I need to find something to work into the system. Any suggestions welcome.
                  • jimrr
                    • Dec 2010
                    • 489
                    it may be full of air?
