Are cylinder head bolts reusable?
  • threesticks
    • Feb 2021
    • 4
    Like the title says, are the cylinder head bolts on my SII 2.25 petrol engine reusable?
    I am in the process or reassembling my engine and getting ready to install the head and can't find much info on whether to use new or reuse the bolts that I already have.
    Thanks for the help.
  • mearstrae
    • Oct 2011
    • 592
    Yes, in the old days there weren't such thing as TTY (torque to yield) non-reusable bolts. So, unless a bolt is damaged in some way, go ahead and use it.
    • threesticks
      • Feb 2021
      • 4
      Were there washers under the bolt heads as well? I don't see any called out in the factory parts catalog.
      • mearstrae
        • Oct 2011
        • 592
        In the old days, washers weren't used on head bolts. Just make sure the bolts are clean as well as the bolt holes in the block, use a slight amount of engine oil on the threads (if too much oil is used a hydraulic lock can occur and crack things).
        • cedryck
          • Sep 2010
          • 836
          check green bible for sequence to tighten.
          • babe6488
            • Jan 2021
            • 5
            If they are the bolts that came off the engine and the engine didn’t blow up or some such that warranted the rebuild, then the bolts are fine.
            IMHO.
