I'm in the planning stages of rewiring my 1961 S2 Station wagon with generator and negative ground. I ran across these electronic voltage regulators that look original. Any experience with them?
Anyone upgraded to electronic voltage regulator?
Most people just ditch the generator (old tech & low output) and go with an alternator (internally regulated) so you don't need to run a voltage regulator.61 II 109" Pickup (Restomod, 350 small block, TR4050)
67 IIA 109" NADA Wagon (sold)
-I used to know everything there was to know about Land Rovers; then I joined the RN Bulletin Board. -
I support, JP view. If you want better electrics, get rid of the pain in the #@*^ generator, Mine worked, but never worked well, although I loved watching things dim when the revs lowered, (old scho0l) an Alternator upgrade just sells itself, Auto Sparks can help you with the wiring harness and put the proper plug in it, cheers.Comment
