Need Help - Knocking Noise - 65 Series 2a SWB Petrol
  • grimmecm
    • Apr 2023
    • 10
    Hey everyone, need some expert help. My series 2a has started making a terrible knocking noise.
    Here is a video (not mine) of the same noise and same conditions.
    He found the head gasket to be the issue but that doesn't appear to be my issue. So far I have replaced the head gasket, cleaned the cylinder head and piston faces, reset clearances on all tappets, new spark plugs and checked gaps.
    The truck starts and idles fine/smoothly. Noise only happens when engine is under load. Noise is the same regardless of engine temp. Feels/sounds like it is in the back end of the engine.
    Would appreciate any insight anyone has.
    Current: 1965 Series 2a Santana SWB.
    Past: 2006 SE V8.
    2.5" lift Johnson Rods, 295/70/18 Nitto Ridge Grapplers, ATX AX201 18x9 wheels, Front Runner Slim Line II rack, Front Runner ladder, Additional fiddling through Gap Diagnostic IID Tool
  • charles1943
    • Jan 2021
    • 160
    Possible broken crankshaft or a bad connecting rod comes to mind. Possible dropped valve head??
    • roverp480
      • Jul 2020
      • 335
      Sounds like something vibrating to me, transfer lever or a heat shield ?
        • 519
        thrust washer someplace, or something in the bell housing. remove the drain plug on the bell and measure the end play on the flywheel or same on front of C shaft. if it's a real tinny issue probably something external but on the video the guy was talking all the time!
        • biffidum
          • Nov 2021
          • 49
          It could be your wife trying to get into the garage...
          • biffidum
            • Nov 2021
            • 49
            In all sincerity, it could be pinging. Your timing may be too far advanced, or your advance mechanism is too aggressive (never seen this though - unless its the wrong distributor). Your valve lash may also need adjusting - which would also sound worse under too advanced timing as they bang shut. Or finally, you may have valve seat regression.
              • 519
              what's the oil pressure like? mine does this and it needs new inserts so it waits for a rebuild. your sounds a bit tinny, not exactly a hard knock, at least on the audio.
              if you have 50-60 psi oil your engine is prob ok, you could put some lucas oil treatment in it, that saved my dozer engine!!
              other than that, biffidum could be tracking on this.
              • biffidum
                • Nov 2021
                • 49
                Disconnect vacuum advance and drive. If noise is reduced under load - bingo. If not, check valves. Valve adjustment nuts should all show similar thread counts, if one has significantly more thread you have a worn valve seat.
                  • 519
                  welll, ya, it does sound kinda like valves ...... but that doesn't happen overnight......... did you change gas type or torque the head or anything that'd affect valve train?
