Engine Oil
  • Jim-ME
    • 1379
    Engine Oil
    I changed my oil and filter yesterday to 10W30 as its starting to get cold. My sump would only take 6 qts before reading full to the H mark on the dipstick. From what I've read it should have taken 6.5 qts without the filter plus I've got an oil cooler as well. Is it possible that I've either got the wrong dipstick or that the dipstick tube slipped into the block so I'm getting a bad level? Thanks,
    Jim
  • LaneRover
    • 1743
    Unfortunately I can't even make an educated guess on the dipstick other than I guess that it is possible that something is amiss with the dipstick and or tube.
    Is there any chance that it takes longer for oil to drain out of the oil cooler so some oil was left in the system? Again this is a guess as none of my Rovers have an oil cooler.
    Brent
    I am sure someone has an actual educated reply!
    • Jim-ME
      • 1379
      Thanks Brent. I will admit that the oil cooler must hold some of the old oil as I haven't found a way to drain it other than disconnect the lines each oil change. I'll bet you're right.
      Jim
      • scott
        • 1226
        math may say that that ain't it...2.25's hold 6.5 qrt, add an oil cooler they take a 6.5 + x where x = the capacity of the cooler, if the oil cooler doesn't drain and hangs on to x you should still be able to get the 6.5 in
        '64 Series IIA 88 Canvas Tilt
        '68 Series IIA RHD Ambulance
        '76 Spitfire 1500
        • LaneRover
          • 1743
          Keep in mind that American and British Quarts are different. Though different in the wrong direction with the problem you are having. Unless of course you have specs in American units and you are filling with British units.
          Do you have another dipstick available to give it a quick try?
          Brent
          • Jim-ME
            • 1379
            No I don't
            • daveb
              • 513
              compare dipsticks
              um, don't know how else to phrase this, but...
              someone else should measure their dipstick for comparison. Jim's may indeed be too short. But he only has one, so help out guys. Measure from the lower edge of the little cap at the top.
              No 2.25s here anymore otherwise I'd go first.
              good luck and godspeed
              Originally posted by Jim-ME
              No I don't
              • LaneRover
                • 1743
                Is there anyone up near you? If you head to Southern Maine and you want to grab one to test with (while measuring and taking a look at the fuel filler on one of my tubs) and then send back to me then send me a private message and we can arrange either you stopping by or maybe my brother sending one up to you.
                Not sure if this will help but I just measured the dipstick on my 1965 109SW. I don't believe that the engine is original to the vehicle but it is a 2.25 liter. The dipstick from the bottom of the bell shaped piece that holds it in place to the bottom of the dipstick is 19 and 5/16 inches long. The dipstick tube is almost perfectly 12 inches from the engine block to its upper tip. (not from the top of the nut that it goes through but from the engine block itself).
                Let me know if you need to stop by or to have my brother send one up to you.
                Brent
                • junkyddog11
                  • 195
                  sorry for the slight hyjack...
                  Brent, where is your brother in southern Maine....?
                  I'm in the Kittery, Eliot area
                  ..and Jim, I can't imagine that you could have a dipstick problem. More likely that all the oil did not drain in the first place. Did you run the motor for a couple min before checking the final level?
                  Matt Browne
                  www.overlandengineering.com
                  "resurecting junk through engineering"
                  • LaneRover
                    • 1743
                    My brother is in North Yarmouth, just down the street from another Rover enthusiast. I have some property in Old Orchard Beach where a couple of my Rovers sit.
                    Brent
                    • junkyddog11
                      • 195
                      Ahhh....so your the guy in OOB. Couple of my offspring live up there.
                      Matt Browne
                      • Jim-ME
                        • 1379
                        Based on info I've gotten from the Series 2 Club forum mine is not an uncommon problem with replaced engines. They told me to loosen the dipstick tube locknut and turn the tube out until I get the correct reading on the dipstick using the correct amount of oil and then tighten the locknut again. I'm going to give it a shot once I get a set of crowsfoot wrenches.
                        • LaneRover
                          • 1743
                          Good to know! Thanks for letting us know what you found out! Just remember to take into account how much the oil cooler holds.
                          Brent
