Choppy Idle - Ideas?
  • grimmecm
    • Apr 2023
    • 10
    Hey everyone my s2a petrol has started having a very choppy idle. Curious if anyone has any ideas. It’s been sitting about 6mo. Here is a video. Any thoughts would be greatly appreciated.
    Current: 1965 Series 2a Santana SWB.
    Past: 2006 SE V8.
    2.5" lift Johnson Rods, 295/70/18 Nitto Ridge Grapplers, ATX AX201 18x9 wheels, Front Runner Slim Line II rack, Front Runner ladder, Additional fiddling through Gap Diagnostic IID Tool
  • roverp480
    • Jul 2020
    • 335
    Is it running on all cylinders?
    • WineCountryRover
      • Feb 2024
      • 13
      Everything tightened down? (Airtight?)
      I dropped off my carb for a rebuild and when I picked it up, the old wise sage of petrol in the shop suggested to stay away from those clear plastic in-line filters as they sometimes can shed bits of plastic into the line (and the carb). He felt so strongly about it he just threw a metal cased in-line filter in the box to save me a trip.
        • 519
        usually it's a air leak but you could check the vacume advance and lines?
        • biffidum
          • Nov 2021
          • 49
          Check your distributor for play. If you put a timing light on the engine you will see the timing mark dancing around.
