I've got spongy brake. A quick second stab firms them up. The problem is distal of the rear flex hose as I can clamp off that hose and get a nice hard pedal every time.
I've bled the snot out of them and for a little while after bleeding the pedal is hard (yes it lasts longer than pumping the pedal and compressing the air bubble lasts).. then after sitting overnight it's gone soft.
There must be some kind of leak to allow air in but in a positive pressure circuit (and a great deal of pressure at that) wouldn't any leak manifest itself as spilling/seeping fluid? Not sucking air as it sits? I see no such leaks.
Also, I've pulled apart the slave cylinders and by all appearances they're tip-top.
I'm beating my head here... Thank you very much for your time--
Josh
Josh
it seem's I do alot of this kind of damage controll lately. well it won't be all fixed today more like all winter.
had to take the round a bout method of getting it but it worked.
