seats and sound
  • PH4
    • 375
    seats and sound
    Is there any difference between the rear inward facing bench seats as far as fit? Are they all the same size?
    I know it is sacrilige, but am considering putting a stereo in my Series 109 SW. Any recommendations for particular speakers and placement of same? Photos would be excellant. Would probably purchase Tuffy Cubby to put stereo unit in.
  • scott
    • 1226
    sacreligious only to the purist (and there's nothing wrong with going that way). i've got my am/fm cd player and xm recvr' mounted in an ammo can in the tub agaist bulkhead behind the passenger, my speakers are alpine marine grade 300 watt and the sit in a cargo net suspended from the rear and mid hoops of my iia 88. i fashion an antena mount to the rear of the passenger door overhead.
    '64 Series IIA 88 Canvas Tilt
    '68 Series IIA RHD Ambulance
    '76 Spitfire 1500
    • scott
      • 1226
      the speakers
      '76 Spitfire 1500
      • scott
        • 1226
        the anteni
        '76 Spitfire 1500
        • badvibes
          • Mar 2007
          • 364
          Scott-
          That is the cleanest I've ever seen the back of your truck! What happened? Hope you and your wifey are having a great few days. Hope to see you when you get back to NM.
          Jeff
          1991 Range Rover Hunter
          • SalemRover
            • Aug 2007
            • 310
            Does that speaker mount come in a D Cup? ;P
            -Jason
            • scott
              • 1226
              -Jason
              i think so...why, do you prefer smaller speakers?
              '76 Spitfire 1500
              • tmckeon88
                • 142
                I put an ordinary Blaupunkt in a small custom made box up against the roofline right over the rearview mirror. 6" speakers in the dash on the left and right hand ends. (Sorry, no pictures right now.) The wires run up either windshield pillar left and right, and the radio power wires can be put in behind the center metal strip of the windshield. Having said that, my radio has grounding issues, so be sure you have good ground and good connections.
                Tom
                1969 Series IIA 88"
                • PH4
                  • 375
                  To those who have installed a stereo, where did you tie in the power cord.
                  • SalemRover
                    • Aug 2007
                    • 310
                    Just having a bit of fun. It's all I could think of when I saw all that fishnet and round speakers
                    -Jason
                    • scott
                      • 1226
                      -Jason
                      jason, it's all good. i look in my rear view mirror and see 'em bounc'n around and think along those same lines, mmm maybe i should change the cargo net for a red lycra sling, sort of like baywatch. (no disrespect to the ladies)
                      '76 Spitfire 1500
