This just happened... I went to move the rover in 1st gear and had some hesitation. Thought it was a locked up brake. So I moved the rover forward in 1st and in reverse with the hope of freeing it up.
After 3 or 4 tries the rover wont go into gear. I get a little noise when I try to go into reverse and 4th but, thats it.
No grinding, peddle for clutch seems to work fine, no overdrive installed, it just wont move. It has sat for 2 weeks thru 3 rain storms and freezing weather change.
Any suggestions would be great..
P.S. thanks Les for the help on the phone earlier. (just looking for back up)
Although, we all know you are the "Rover answer man"
