I have a zenith carb on by 73 SIII. Next to the volume control needle valve there is an open port with nothing in it. From asking around I think I've determined that this is where a solenoid valve was. I was told that this solenoid was to prevent dieseling when shut down.
When the solenoid is picked (engine running) I assume that the plunger lifted, opening the port in the bottom of the port. I have nothing in this port at all. First I would prefer not to replace he solenoid, unless this will cause operational problems. If I do run it without it what should I do with this port, plug it with the port open or closed. Could this port being open cause my vehicle to stall each time I back off on the throttle?
