I recently recieved my parabolic kit from our host onto my Series III 88 after 3 months of anxious waiting. I have since installed the springs and shocks, and have run into some issues that I hoped someone on here may have knowledge of. Every person that I have mentioned the word parabolic to in town has simply given me a blank stare...
1. To make things clear, before the parabolics, I had the original springs and shocks, which were old and worn out and sagging, but the vehicle WAS in alignment and tracked well.
2. Now, with the new springs and shocks, the rear axle seems to be shifted to the right side, in other words, my back wheels offset to the right of the vehicle compared to my front wheels. How is this possible considering the fact that the spring pin simply lines up with the recessed hole in the axle? I noticed that the left side of the rear axle is solid with the hole in the middle for the spring pin, while the right side is not solid, the entire "plate" that the spring sits up against is hollow, although there is still a separate round recessed hole in the center. So, yes, the springs are in the correct holes. I've checked repeatedly.
3. There seems to be some kind of grinding when I suddenly hit the gas or suddenly decelerate. It sounds like it's coming from the transmission or drive shaft, but I can't be certain. It almost seems like my driveshaft is at too extreme of an angle now, and that it might be rubbing at the yoke areas.
Could adding shims to the axle to decrease the driveshaft angle solve this?
4. And last, and probably least important at this point, there is a loud popping sound when I hit small bumps coming from the front right. Maybe the spring settling in, but it sounds like a blown shock or the shock itself bottoming out. Just one more problem...
If anyone on here has installed this kit from RN and has had similar issues, or just might know the answer otherwise, please let me know. I know I won't get very far with anyone locally, i.e. an alignment shop, I've already asked them too and they said there was "not much" they could do.
