parabolic spring confusion
So, does this mean if you by a remanufactured frame for a Series III, 88 inch the mounts will be in the 1983 position since production ran until possibly the end of 1984 when they were replaced by the Ninety?Ideally when the vehicle is at rest the shock should be mid way through its travel. BUT Series shock mounts are mounted closely together and a shock can easily reach its limit with parabolics and even with new stock springs. LR fixed this problem in 1983 by moving the shock mounts farther apart so longer shocks can be used. What people usually do with parabolics is mount a longer travel shock that allows increased lower articulation at the cost of upper articulation. Some folks cheat and fabricate new shock mounts that are farther apart than stock.1974 Series III 88 RHD
19?? Series IIA 88 LHD (parts)Comment
