Series IIA tranny question
  • duffymahoney
    • 2
    Hi all,
    I'm looking at either a tranny replace or adding an overdrive to a 1970 IIA. I need to get a top speed around 70mph as it will be daily driven and sometimes on the highway. I would like all input. Thanks
    Duffy
    • 399
    re: Series IIA tranny question
    The easiest way is to install an overdrive unit. The Roverdrive unit has the best reviews, but I run an old Fairy in my SIII. 70 mph is about the fastest I would want to go, considering the capability of the suspension and brakes. Another option is to fit a high ratio transfer case, which allows for a better high speed option but does not affect the original transfer case low range gearing. 5 speed transmission options will require chassis alterations, like repositioning crossmembers and custom length driveshafts. The transfer cases on the later transmissions are designed for full time 4 wheel drive and are to be used with CV joints on the front axles, not with U-joints as on the Series axles. The LT-77 is supposed to be an easier conversion into a Series chassis compared to the R-380, but I have not messed around with one yet.
    I'm just finishing a 3.9 V8 and R-380 into an SIIA 109, which required both crossmember work and custom driveshafts.
    • scott
      • 1226
      i've a fairy od in my '64 iia 88 and top end is 60, 70 on a good desent
      '64 Series IIA 88 Canvas Tilt
      '68 Series IIA RHD Ambulance
      '76 Spitfire 1500
      • fruitpunch
        • 109
        I second that 70 mph with a 2.25 is a bit ambitious and most likely not worth all the upgrades, puttering along @ 55 mph means you usually get there within 5 minutes of the 70 mph crowd specially commuting or in dense traffic. Now hills you will be be slow anyway, so just my 2cts this might be more complicated then just an O/D
        1967 MGB convertible
        1966 SIIa 88 Softop Perkins Prima Powered
        1964 SIIa 109 Rosenbauer TLF
        1976 1ton Rapier missle Sankey trailer
        1996 BMW 1100 GS
        wanted ! 107 wagon / 110 wagon v8 or 300tdi
        • yorker
          • 1635
          Is this with a stock 2.25? How flat is this highway? the LR will be a lot more comfortable at 55-65, as will you.
          Matt Nelson
          Land Rover UK Forums
