I just purchased this 1970 Series IIA and my first Rover. I drove it from south Fla. to Alabama (a little over 700 miles) without any trouble.
After a week of driving great, the temp started to cool off in my part of the state, so I used the choke when starting on Fri morning (I pushed choke back in after it started). Two things happened that night on my way home from work.
First, it has almost no acceleration power, esp. when going uphill. You can walk faster uphill than it will currently drive. It starts and idles fine, however.
Second, it makes a semi-high pitched rattling noise that gets worse with acceleration, esp. in 3rd and 4th. It will make the same rattling noise when in neutral and depress the accelerator. With the bonnet up, the sound appears to be coming from the fan/radiator shroud area. It almost sounds like the sound of a coin tumbling in a drier that occasionally hits the sides of the drier drum.
Any thoughts for this first-time Series owner?
Thanks!
Chris
