Would like to know if anyone has tried 4.1:1 diff gears and if you liked it
4.1 Diffs
With a stock series motor? 4.11's are not cheap and would seem to be a waste of $$$$. If you want higher road gearing, the equivalent of a Hi ratio transfer case, then get some used 3.54 gears for cheap. Of course either way you loose your lo range gearing, an overdrive might be the thing for you.The Goat, 2.8 Daihatsu Td, '73 coil conversion
