9" or 9.5" clutch plate
  • lew_sa
    • 21
    All,
    Got the Dormobile running after 6mos of wrenching, cussing & buying. I need to replace the clutch now, but am unsure of whether to buy to a 9" or 9.5" clutch plate. FWIW, it's a '65 Dormobile with a 2.25 petrol & a non-synchro tranny. It's not clear to me in the green bible which clutch I should use. Any advice is appreciated. I'd like to get parts on order so I get it fixed up next week & usable before the New Year. Thanks!
    R/,
    Lew
  • 4flattires
    • Aug 2007
    • 424
    Clutch disc?
    If by clutch plate you mean clutch disc, then it is predetermined by the flywheel and pressure plate measurements.
    Post your measurements of the pressure plate diameter please?
    Jeff
    64 SIIa 109 all stock
    69 SIIa 88 all stock
    Old tractors
    New Harleys
    Old trucks
    • scott
      • 1226
      i just put a 9.5 prsr plt and clutch on my 64 iia swb. it fit and i figure bigger is better
      '64 Series IIA 88 Canvas Tilt
      '68 Series IIA RHD Ambulance
      '76 Spitfire 1500
      • luckyjoe
        • 335
        I'll second the 9.5". I put one on my '65 exMoD 109. My flywheel was set-up for either 9" or 9.5". You will need the clutch AND cover, and the cover must to be the IIa version with center boss, NOT the III version.
        Visuals:
        Regards,
        Tom P.
        1965 exMoD 109
        1995 RRC LWB w/EAS
