What kind of Rover is This?
  • bullstanky
    • Dec 2007
    • 119
    So this is my new Rover http://cgi.ebay.com/ebaymotors/ws/eB...179834411&rd=1
    A bunch of y'all have looked at her and most have decided that it is a series III. Now I just need to figure out what engine, transmission and differentials I have. Here are the serial numbers. I'd appreciate any help that points me toward what I'm working with!
    Engine - Ford XSYJ12H008
    Transmission - <BIRMAID> 2
    576653CA
    LM22W
    A
    Rear Differential - 8HA-004-17D
    Thanks for pointing me in the right direction!
    '75 SIII 109 Diesel - I'm in deep.
  • msggunny
    • Jan 2007
    • 621
    Page isnt responding, post pics!!!!
    04 DII
    08 D3 (LR3)
    • bullstanky
      • Dec 2007
      • 119
      this one should work
      • O'Brien
        • Oct 2007
        • 134
        have you checked to see if the numbers on your black plate match your frame horn? based on the 251 prefix in the VIN listed in the auction, it is a home market (britian) 109 from approx '64
        check it out
        it's that's the case, it's seen some major changes in fittings since it left the factory. check your numbers on the plate and frame horn.
        Matt
        '66 88 GM powered
        '89 SWB RRC (sold)
        '67 109 NADA 6cyl. Station Wagon #2 (sold)
        • bullstanky
          • Dec 2007
          • 119
          [quote=O'Brienhave you checked to see if the numbers on your black plate match your frame horn? [/quote]
          Where are the numbers on the frame horn?
          • bullstanky
            • Dec 2007
            • 119
            576653CA
            LM22W
            A
            Anybody ever seen a "Birmaid" brand transmission on their series rover? The only google reference that comes up for "Birmaid" is in a forum where "Birmaid" is mentioned as the manufacturer of a twin cam cylinder head casting for an early lotus Elan S2-S3/Cortina era vehicle...
            • leafsprung
              • 1008
              Looks like a ford transit diesel mated to a rover trans/t-case with a salsbury rear.
              • bullstanky
                • Dec 2007
                • 119
                Thanks for the info - do you know where I would find info on the specs of this ford transit motor - like hp, torque, etc?
                • yorker
                  • 1635
                  post here for more info on them- loads of them over there:
                  Land Rover UK Forums
                  • rovertek
                    • Apr 2007
                    • 188
                    its obviously an early 2a/2 dr 109 with a conversion engine and a late model 2a nose most likely erected from parts.....
                    • leafsprung
                      • 1008
                      Its obviously not . . .
                      • S11A
                        • Apr 2007
                        • 218
                        I will defer to the experts, but here is what came back from the VIN decoder at:
                        The Clifton website provides info on scientific text services, about the Linux BogoMips mini-Howto, off-roading in a Land Rover Discovery, and Arabic calligraphy on oriental rugs
                        CalVIN, the Land Rover VIN CALculator
                        25106443B
                        251 Model: Land Rover, Series IIA
                        Body type: Basic
                        Wheel base: 109in
                        Engine: petrol
                        Model years: 1962-1971
                        Destination: Home market, right-hand drive (RHD)
                        06443 Serial number
                        B Design: One significant design modification
                        Suffix used from March 1963 till April 1966
                        Definitely not plain II.
                        I would guess late IIA, but didn't the dash get padding with the III, or did it with the late IIAs? Not that that couldn't have been added...
                        1965 Series 2A 109 pickup diesel
                        • leafsprung
                          • 1008
                          Rover
                          Calvin will tell you where the VIN plate came from. I think we have all seen enough defenders with series VINs to know that the VIN does not always tell you much about the vehicle itself. This is a good example of that.
