Brake pedal reserve distance on 1971 88” 2a with factory servo
  • slowpatina
    • Aug 2020
    • 66
    I’ve looked around with no luck… anyone know what the brake pedal reserve distance is/should be on a late Series 2a with a factory installed servo? (I recently replaced the original servo). Thanks
    • 519
    2-1/2 inches would be pretty tight, I think that's what the book says. when it gets to 5 click the adjuster and it'll do wonders.
    • slowpatina
      • Aug 2020
      • 66
      Thanks, jimrr.
      So, with your 2 1/2" distance in mind (from pedal to the floor when brakes are applied), I today measured that pedal height when stopped during a long test drive (with new servo, master cylinder, and, rear brakes 100% rebuilt). The unpressed pedal height (same as when I bought the truck) is 7 1/2", and when applying the brakes (engine idling/servo active) it pressed downward 3", being 4 1/2" from floor (the "reserve distance"). Pedal seems fairly firm, to the degree I chirped the rears a couple times when testing rapid/hard braking, and the reserve distance seemed same around 4 - 4 1/2"... ie: not much different than normal braking to a casual stop or at idle.
      All in all, the braking felt very responsive and reliable. I was concerned on the first test drive a couple days ago though that the pedal moved down too far and went too low, but that perhaps seems not the case. Is it okay to consider the braking performance is acceptable with the reserve distance being almost twice that of what the book mentions? My mind thinks it shouldn't be an issue... but I've not done brakes several decades.
      You mentioned "the book", which one? (I either missed seeing the measurement in books I have... or I need better books)
      Thanks again.
        • 519
        that brake measurement should be called 'free play' and is the distance from static positon to depressed (to the "firm" part) ....... 2-3 " should be ok with 3" about as far as like it. when I adj. my brakes I have the wheel jacked up so you can hear and feel the shoe engaging the drum and have it adjusted where you don't feel or hear it. if you think your brake might be tight "dragging"" your brake drum will get hot, it'll be harder to turn the wheel and in extreme you'll feel it while driving and you'll smell it, and see smoke maybe ......... so it's always better to have them ''looser'' than tighter. Landrover is pretty good about adjustment selectability so you can have the pedal pretty well ''topped up'' without dragging a shoe.
        the BOOK" i refer to is the factory manual(s), on here referred to as the ''green bibile''. if you can find one there is nothing comes close in detail. you have to learn ''english'' sometimes but it covers everything down to bushing a cam shaft, adjusting ring/pinion and everything else.
        • slowpatina
          • Aug 2020
          • 66
          Yes, the 'free play' aspect you mention is 3" until pedal is firm, and what seems called the 'reserve distance' is 4 1/2" from firm pedal (fully pressed) to floor. Total pedal height (unpressed) is 7 1/2". The clam shells are backed off just shy of shoes touching (spin tested on jack stands), and I set the servo's push-rod about 1/16"-1/8" away from touching the master cylinder push cone. Seems there's no need to tweak anything further, so when it stops pouring rain I'll do one more close-to-home test drive to break in the shoes a bit more, before doing a faster/longer distance run.
          I don't have the green bibles but do have a 1969 version of the white covered LR workshop manual 'Part Two'. I must need new glasses if I missed seeing any pedal distance info. I'll take the truck on it's first lengthy jaunt... to the optometrist!
          Thanks again for your input, jimrr.
          • roverp480
            • Jul 2020
            • 335
            The Factory Workshop manuals changed colors a couple of times , my part one S2A is Green and part two which I purchased first is White.. The First Workshop Manuals were Green. The initial parts lists Click image for larger version  Name:	S2 Parts book Options.jpg Views:	0 Size:	115.8 KB ID:	192873 when the model was fisrt introduced were white with green writing and red Land Rover Zig Zag
              • 519
              i've dreamed of having such a catalog as ""optional equipment"" for i've read since the 60's of options they use to offer, right down to the built in coffee maker....... or more probably tea?P480??
              • slowpatina
                • Aug 2020
                • 66
                Back at this after thinking I was done, but ended up having to purge and replace front lines... then re-bleed. But now there are issues with pedal height/low reserve distance.
                As a refresh, 1971 late 2A with servo (as OG shipped). All new brake parts at wheels, incl drums. New DMC and servo (still have the old OG's if anyone wants them).
                System bled with vacuum pump on jack stands. DMC bench bled. Bleeder nipples not sucking in air. Solid, bubble-free outflow. Pedal high/firm with engine off. Upon parked start up, with foot on pedal, it goes down a bit as expected, thus servo is working. Vac lines and servo check valve checked, seems all good. Clamshells adjusted. Reservoir level unchanged after ~65 test miles. No leaks.
                > When driving, pedal needs pumping ~2x until firm, else goes uncomfortably low to ~2.5" from footwell (being a ~5" drop from static, jimrr 's aforementioned 'free play'). Regardless, truck stops great, can even make it skid. No sideways pulling.
                >> I'd like pedal to firm up sooner, and will re-re-bleed, so my enquiry this time is about shoe positions for bleeding. I've read numerous related posts online, and for every one saying have shoes snug against drums when bleeding (clamshells pushing), there's an opposite post saying have them backed off all the way ‘in’ so the wheel cylinder has less volume and potentially less air trap space... but shoes would be further from drums.
                >>> With what I know, shoes 'in' approach seems logical, but is there truly a best way or does it actually even matter much during bleeding?
                Running out of bleeding patience, so any detailed input from experience much appreciated.
                  • 519
                  of course having the cylinders shortened is always good but this Ain't no race car and i've never had discernable air issues doing it on flat and level ground. My advise is just assure yourself you've gotten any air out and drive the rig for a few months or say a couple hundred miles or a lot of brake use then bump those adjusters up till it's almost dragging the drum, re-bleed if you feel inclined and you'll probably be about like most any Land Rover on the road. on that vacuum bleeding, don't use max vacuum, if you have help and you've never done it the old way, try it, just make sure the pedal is still going down when you shut the bleed valve. and use slow motion on the pedal, be patient, and leave the cap on the resevour loose till you're done.
                  • slowpatina
                    • Aug 2020
                    • 66
                    Been meaning to follow up with the resolution. In post #5 above I'd mentioned "The clam shells are backed off just shy of shoes touching" which was true two of the wheels. The other two I did 'adjust' the clams but they ended up backed off all the way because the drums still rubbed a bit at specific rotation points, but not rubbing all the way around as you spin them, and not rubbing to the degree you couldn't rotate the drums forwards or backwards. I didn't think to mention this initially, but really should have. The rubbing is likely since they're yet to be bed in from miles of driving and/or I didn't have a shop turn them true in case they weren't perfectly round. That said, on those two wheels I had left the adjusters backed off all the way and was thinking they were 'adjusted' just fine, ie: I didn't want MORE rubbing, and I couldn't make the rubbing any less... and the brakes worked well despite the low pedal concern.
                    Long story longer, I ended up re-adjusting those two wheels their backed-off (rubbing a bit in specific spots) position. Meaning, I moved the clamshells/shoes 'tighter' (the only option available) until the rubbing increased a little more (ie: changed)... and THEN I backed them off a tad until the rubbing was back to the known/experienced rubbing, which I learned started before being backed off all the way like I'd had them. Thus, the difference was the shoes were now physically closer to the drum but not rubbing any more than when backed off completely... it was just a few clamshell clicks of a difference, and it fixed the low pedal issue I was stumped by. Hope that makes sense.
                    Now the pedal reserve distance (footwell to pedal height when pressed, engine on) is 4.75"...which I'm very happy with, instead of the 2.5" height from floor as mentioned above ...which felt rather sketchy low.
                    Note that the 'reserve distance' I was measuring is a different established measure approach than @jimrr's aforementioned 'free play' measurement, which as he kindly shared is the 'distance from static position to depressed'. Either way you measure, you'll obtain pertinent pedal height info.
                    Now to the next item on the list... high tinker value these Series Rovers
                      • 519
                      ok, I'll accept it looks like you've done a good job so i was thinking maybe you have a high point in the brake line, a non-standard brake line that could have a loop going up in it that might possibly trap some air and that bubble just stays in the loop? another theory is the air is in the master cylinder. ford truck want you to bench bleed the master cylinder before you install it, i've never done this with land rover but it sure sound like you have a persistant bubble somewhere. check out that ''tipping valve'' on the brake system too. i've never had a issue with one but who knows?
                      • slowpatina
                        • Aug 2020
                        • 66
                        Hey jimrr, Just seeing your 5/27 reply. Not sure if you saw my 5/24 post (#10 above) that shared the solution. The post was seemingly 'unapproved' initially, potentially not visible for several days. RN confirmed it's all good now and visible to anyone logged in or not.
                        That said, yep, I bench bled the new master cylinder prior to first install, and on the reinstall after fitting a new front brake lines, as mentioned in prior post. Seemed well worth it as no issues there. As for tipping valve, my 1971 late IIA doesn't have one (since day one), just a junction for front and rear lines. Thanks again for all your input.
