Wiper Switch Wiring
  • RoverKid_1972
    • Mar 2015
    • 40
    Wiper Switch Wiring
    Hey all,
    Having difficulty deciphering correct wiring for wiper motor and switch. I have a brand new switch (Model #: PLE809) and 2 speed motor (Model #: PLE652). The wiring on the male plug is pre-existing. Unsure if factory or modified. There seems to be a light-blue/green wire coming from tab 3 which does provide a higher wiper speed when connected on the male plug but I can't find this on any wiring diagrams. There is also a brown/green wire coming from tab 2 on the male plug which I do see in the diagrams although it seems to be carrying power TO the switch instead of FROM the switch. The setup outlined below does give me 2 speeds but I'm left with nowhere to connect wire #2 and the motor also does not self park when switched off. Any help here would be greatly appreciated
    Current wiper switch setup:
    1. power in (green)
    2. low speed (red/green)
    3. high speed (light blue/green)
    4. empty
    5. washer motor (green/black)
    Switch positions:
    1. Off (power only to tab1)
    2. low speed (power to tab 1, 2, and 4)
    3. still low speed (power to tab 1, 2, 3, and 4)
    4. high speed (power to tab 1, 2, and 4)
    5. washer motor when plunger pressed in (power to tab 1 and 5)
    Original diagram does not show a blue/green wire:
    I am trying to identify if I have the right setup here.
    1. ground (black)
    2. unknown (brown/green)
    4. power (green)
    5. low speed (red/green)
    Continuity of male plug:
    • 1 to 4 (ground to power in)
      • this makes sense as there should always be continuity between these
    Continuity of female wiper motor receiver:
    • 1 to 5
    • 1 to 3
    • 2 to 4
    • 3 to 5
    1972 Series III Frankenstein
    • 399
    Only the later trucks had two speed wipers, so most of the wiring diagrams don't sow them. The park function is by park switch contacts on the wiper motor itself, and the green power wire on your 5 spade wiper motor plug supplies the power for the motor to park. The following link is for a Triumph two speed wiper motor circuit, but the wiring and motor are essentially identical.
      • 517
      also; there may be a resistor to cut voltage so the wiper runs slower............... sorry, I can't parse this out as it's after drinking time............ but this is a simple answer (after you figure it out}!
        • 399
        I've never seen a resistor on the Series wiper circuit, but they can be found on the two speed heater blower motor.
        • EmptyQtr
          • May 2008
          • 3
          Greetings, you have a federalized series loom. Looks to be a late 2a or very early 3. I’ve attached two diagrams from our host’s old catalogs that show what you have. It really looks like you have the 2a loom, although the PO may have spliced in a section to a 3 loom. My loom is a late 2a and looks like your photos. And it has the blue/green wire.
          Cheers,
          Armando Robledo
          Rides
          1971 Series IIa SWB, “Da Beast”
          1999 P38 Range Rover, “Goldilocks”
          Armando R.
          1971 Series IIa SWB, Da Beast, owned 32 years
          1999 P38 Range Rover, Goldilocks, owned 8 years
          • roverp480
            • Jul 2020
            • 335
            The motor has three brushes , connecting two different variations makes the motor speed change
