How Do I Properly Use a Delete Kit?
  • yolikax
    • Oct 2025
    • 17
    Hi everyone,
    I need some guidance on using a delete kit. I understand it’s designed to remove unwanted files or data, but I’m unsure about the correct steps, safety precautions, and possible risks. Has anyone used one successfully?
    Are there best practices to prevent accidental data loss when installing a 6.7 Powerstroke delete kit? Do different delete kits vary significantly in how they work?
    Any detailed advice, tips, or personal experiences would be really helpful. I want to make sure I use it safely and effectively without causing problems.
  • yolikax
    • Oct 2025
    • 17
    Originally posted by yolikax
    Hi everyone,
    Are there best practices to prevent accidental data loss when using a 2012 RAM 2500 delete kit? Do different delete kits vary significantly in how they work?
    thanks in advance for any help
    • jimrr
      • Dec 2010
      • 499
      you won't find many on this section of the forum using this sort of equipment. Series 1,2, and 3 Landrovers ceased being manufactured in the mid-70's before computers were in cars!
      • thomasfrank
        • Mar 2026
        • 5
        Delete kits vary by hardware and tuning, but the tune quality is the most critical factor for reliability. Always back up your stock ECU, follow instructions carefully, use a reputable tuner, and monitor temps after install.
