I've never seen rubber caps, must be because you have Defender diffs. I don't know if the metal ones would fit, but I got a complete chrome set for $5 each from RDS.
Those are the standard coilsprung parts. You can tell because they only have 5 bolts in the drive flange as opposed to 6 on the series and the caps are rubber not steel like the series.
I apologize. I guess I've had difficulty searching for parts through the host site. Can you do a search for words rather than a part #?
Yes, you can do a search for words in the Part # Search area. This searches through the following:
- Product Description Name
- Rovers North Part number
- Manufacturer part number
Most of the descriptions are defined backwards in typ Land Rover catalogue fasion, ie; "Hub Cap - Ser II, IIA & III Galvanized" as opposed to "Series II, IIA & III Galvanized Hub Cap". Put your British thinking cap on . I'm working on updating daily...
This part ref is RNE186 and if you put in the search term "hub cap" the results show it as the first listed part. You can also refine the search results by using the drop down menu "Filter By Vehicle Category", in this case it would have been for Defender 90/110.
