My IIA's control valve for the heater blew, and I am awaiting back-ordered part from our hosts to repair it. When I do, I want to drain and flush the radiator.
Can y'all give any tips to a rookie on draining and flushing the system?
Also, what type/brand of rad. fluid do you recommend?
What mixture of fluid and water do you recommend? Winter temps in Birmingham, AL often dip below freezing and occasionally into the teens.
Finally, I have a late IIA (1970). There is no "obvious" place for a heater control lever to go on the dashbooard. Prior to the valve going, I just opened bonnet and open/closed lever on valve assembly.
FYI. I am running a 2.25L petrol.
Thanks,
Chris
Thanks,
Chris
