Hand crank
  • yank
    • Nov 2007
    • 191
    Hand crank
    Did hand cranks come with all trucks or are they an option? If I had a hand crank where would I find it?
    72 SIII
  • Les Parker
    • May 2006
    • 2020
    Always fitted to Series vehicles. Generally fitted behind the front seat on 88" and 109" hardtops. On Airportables, there is a special hold-down on the RH side of the bonnet.
    Les Parker
    • TeriAnn
      • 1087
      The hand crank also comes in handy if your battery is low and you need to do some winching.
      Very slow due to all the gearing, but it works.
      • Jeff Aronson
        Moderator
        • 569
        Les is right; there are clips behind the seats into which the crank mounts. And you really can hand crank a well-tuned engine. It's a lot of effort, particularly when the engine oil is thick from the cold.
        The hand crank required a hole in the front bumper through which you inserted the crank. The Series III front bumpers don't have the hole, so you can't use a crank on them.
        Jeff
        Jeff Aronson
        Vinalhaven, ME 04863
        '66 Series II-A SW 88"
        '66 Series II-A HT 88"
        '80 Triumph TR-7 Spider
        '80 Triumph Spitfire
        '66 Corvair Monza Coupe
        • leafsprung
          • 1008
          huh?
          not true, even the early RRs have hand cranks
          • Terrys
            • May 2007
            • 1382
            years ago (30+) I used to handcrank mine every day through the winter. They rear main leaked enough to sling oil onto the starter and the bendix wouldn't engage below about 20 degrees. That truck almost always started on the first flip of the crank.
            For the newbie who wants to try it; word of caution; always pull up, not push down.
            • galen216
              • 236
              Jeff
              Both my '76 and '74 SIII's have had the bumper and hand cranks.
              My new NADA truck has the hand crank in clips on the left side rear tub. My friend's '73 has it in the same exact place.
              74 SIII
              96 Disco SE-7 5 Spd.
              • Daurie
                • Nov 2007
                • 251
                My s3 has the hole. The other day just for the heck of it I hand cranked my truck. It was cold, I didn't pump the acclerator, and it hadn't been cranked in a few days. I turned it till I felt a compression stroke and bumped it. It fired up and didn't miss a lick. The guys at work liken my engine to a sewing machine..
                LOL Speaking of... Back in my RX7 days I was ragged on quite a bit untill my "sewing machine" rotary shut down many worked over Mustangs.
                '73 SIII 88"
                Turner 8:1 Engine
                NRP Exhaust
                Roverdrive
                RM Parabolics
                OME Shocks
                Warn 8274
                Pangolin4X4 bumper
                • friar mike
                  • Nov 2007
                  • 116
                  My 1980 SIII has the crank also but I haven't tryed it yet.
                  Onward threw the fog
                  • Jim-ME
                    • 1379
                    The hand crank works!!! I have cranked a Rover at 20 degrees below zero and would not be without one. Just remember to tuck your thumb because if you ever try to use a hand crank and forget the thumb tuckr you will face potentially substancial injuries to your hand. My second Rover came without the handcrank and it was one of the first items I purchased. Learn to use it! Also very useful when adjusting the valves.
                    Jim
                    • yank
                      • Nov 2007
                      • 191
                      I checked behind the seat. Nothing there. I did find what looks like the end of the crank. It has male threads on one end of it.
                      I'll have to pick one up.
                      72 SIII
                      • thixon
                        • 909
                        My old SIII had the hole in the bumper, and the handcrank. It came in handy when it was time to run the valves!
                        Travis
                        '66 IIa 88
                        • KSMTAW
                          • 93
                          I have had to crank my 1970 IIA 88 several times over the past 14 years.
                          Does it only work on trucks with a generator? Or will it work with an alternator also?
                          Todd
                          Southern Maine
                          Todd
                          66 IIA 88"
                          93 Porsche 968 variocam 6spd
                          50 Ford 8N
                          • thixon
                            • 909
                            Generator, alternator, doesnt make a difference. It works on both. The charging system has nothing to do with it. Just make sure the ignition is in the "on" position.
                            Travis
                            '66 IIa 88
                            • Terrys
                              • May 2007
                              • 1382
                              Works fine with either, except, you need to have at least a little charge left in your battery to fire the coil. That is usually the case when the battery just doesn't have sufficient cranking power to turn the engine over. In my case, the starter bendix simply wouldn't engage. I only had to do it first thing on cold mornings. Once the engine got heated up, the residual heat was sufficient to warm the starter shaft enough to allow the bendix to travel out and engage the ring gear.
