I'm having minor ignition timing issues that are more baffling than problematic. I have a Turner 8:1, 2.25 Petrol engine in my S3. Lucas 45d dizzy with Pertronix unit. The reccommended timing per Turner is 3 to 6 deg advanced static (obviously)
I know timing has been discussed to death nearly on here and I have gone through all the methods explained but always seem to fall back on stroboscopic timing method as it's never failed me in the past.
Whats happening is if I set it at 3 deg adv and plug in the vac adv unit everything seems fine then once everything evens out I get a little poop / pop out of the exhaust which is also percieved as a slight miss if you were at the front and couldn't hear the exhaust. It's very random but happens regularly at idle. I've pulled plug wires to try and isolate it to a particular cyl. but as the idle and vaccuum (timing) decrease the miss dissapears (except, obviously, the miss of the cylinder I pulled the wire off). If I advance any more than 3 deg it gets worse. I rechecked all the valve clearances and everything is spec. My vaccuum advance, advances 25 degrees at 750 rpm. Does this sound right? I haven't gone as far as checking the advance curve but I believe the unit to be good as it was new in 2006. I get no pinging or valve rattling under running conditions and frequently have full throttle accelerations in 3rd and 4th up to 3500 rpm that are very smooth.
The PO stated that he found the timing to be best set at a little higher than 6 deg adv! Which is also confusing me because I have no doubt that it was set at that and don't remember the popping when I bought the truck.
Any ideas??
Any ideas??
As easy as it is I don't know why I haven't yet anyway.
