Thats exactly where it came from.
Clive is a good guy and was very honest about the condition. It is one heck of a truck!
What do you do with your Rover?
Daurie, would you happen to have a side profile photo of your series 3? I'm in the middle of painting mine and can't decide on whether to paint the rear window section on the top limestone, like yours, or paint them pastel green. I've beeen looking for a photo everywhere but haven't had any success. Thank You.'73 Series III
'03 Disco
'76 BMW 2002Comment
I use my '57 ser1 as my daily driver. I use it to get to work, gather wood, go hunting, hiking, and just because I want to do some gentle puttering around the countryside.
Uprated motor to a 2.25
insulated top and doors
delco alternator
24,000 btu aftermarket heater
custom made electrical
frame up rebuild
Otherwise its all Landy
JonComment
Moving a thousand pounds of gravel into a concrete form.
Moving a 400 pound door into position.
This door is 7'6" tall and 7'6" wide and connects my attached workshop to my garage. It is a sliding door, made of cedar and stainless
Other than the occasional heavy haul, my Rovers mostly see action on the weekends.
I just got 6 rolls of film developed and I've got some great photos to share. I'll try to get them posted in the next couple of days.Last edited by jp-; 01-24-2008, 10:57 AM.61 II 109" Pickup (Restomod, 350 small block, TR4050)
67 IIA 109" NADA Wagon (sold)
Howdy Tim,
The tires I use (front and rear) are LT215/85/R16. A 10ply commercial truck radial. The tread block are ciped so snow and ice traction is excellent. Brand new they look like this:
I ordered them 3 years ago from Katona Tire in Vancouver, BC. They are remanufactured from intact casings, not retreads. When I bought them they were around $100 CAN each. No enviro levy because they were remans
. Quiet on the pavement. Grip the snow and ice well and lets it climb like a mountain goat. My first pic was taken at the summit of a 6800ft mountain top with lots of shale to get there. I have used lug mud treads in the past and have settled on these for a good all arounder. They will probably dry rot off the rims before they wear out on a ser1.
JonComment
Jon, Do those tires have all steel casing?? I run 265/85 16 Michelin XPS Tractions on my truck and was considering them for my Rover but was hesistant because of the steel sidewalls. Not sure how the ride would be and how it would do aired down.
I know one thing, its one heavy tire!'73 SIII 88"
Turner 8:1 Engine
NRP Exhaust
Roverdrive
RM Parabolics
OME Shocks
Warn 8274
Pangolin4X4 bumperComment
Howdy Daurie,
Heres a link to the Katona Tire site where I bought them from:
Their technology is not a bunch of BS like some auto stuff. They are great and I wouldn't hesitate to go with them again. I do believe there is steel belting, as for it being bead to bead steel
. I mounted them myself and they are a stiff. I don't air down my tires as I mostly drive on rocky surfaces. How they work for that I don't know. Probably would be safer with tubes for that at low speeds. I run them tubeless on the original ser1 rim.
Caveat: I do not work for them and I don't get compensated for testimonial (I wish)
Jon M.Last edited by gudjeon; 01-25-2008, 01:09 PM.Comment
Snow plows
Hello Ryan.. I remember the "Grover" from many years ago when the CT "Yankee Rovers" club was in existance. It's good to see it's still around. My SIII was also on the road then too.. Not the case any more.. still being rebuilt.
That a nice simple plow frame set up.. nice fabrication work. Does it have struts further back on the chassis? It sure lifts the plow up high
You write:.. " You can't beat a rover for pushing snow."
Well maybe?? this is what I use (see attatched).. Power steering is nice as well as a tight turing radius.
And here is a shamless plug for an ebay Item I have listed. Its an older but working, 2-way western hydraulic lift/pump assembly.
It works fine and those that seem to be looking for rover plows, this would be could staring point. I've since upgraded to the 4 way version for my old truck (the meyers E47 unit is did not perform very well for me.)
Talbot, southern MaineLast edited by TJR; 04-26-2008, 10:25 AM.Comment
