2.25 engine options
  • PH4
    • 375
    2.25 engine options
    I would appreciate any and all advice in regards to experience with different suppliers of 2.25 rebuilds. The different options I am looking at are RN,BP, DAP, and any others suggested to me.
    Also, what compression and what is signifigance between 3 bearing vs. 5 bearing. In addition any suggested upgrades "while I am at it"? Currently have a Zenith, keep?
  • PH4
    • 375
    Let me add Turner engines to the mix.
    • yorker
      • 1635
      The 5 bearing engines were the later engines and the bearings refer to the ones the crank shaft runs on, the 5 bearings offer more support for the crank. If given the choice between the two I'd choose 5 bearing assuming the price was the same or close to it.
      Land Rover UK Forums
      • TeriAnn
        • 1087
        I'm sure each of these companies can provide you with a very high quality rebuilt engine. I doubt if anyone could find any difference in the quality of a pure stock remanufactured engine offered by any of these companies, or Turner for that matter. Where you start seeing differences is when you order "performance" engines.
        Since the quality of each company's remanufactured engine is excellent, I would pay more attention to warranty and the cost getting the engine home. Just in case there is a problem, you don't want to have to ship the engine to the UK for possible warranty work then pay to have it returned to you. Also US remanufactured engines are likely to provide more for your dollar spent, since you are not paying for labour in pounds plus the shipping across the Atlantic. I'd likely pick the source closest to my home to keep shipping costs down. You might save a bundle if you can pick up the engine in person and drive it home.
        Compare warranty & shipping costs.
        The Land Rover petrol and diesel engines shared the same block design. When Rover wanted to offer a turbo diesel they had to strengthen the bottom end. So the petrol version got 5 main bearings & the extra bottom end strength because the 2.25L turbo diesel needed it. I don't see any functional advantage to having a 5 main 2.25L petrol engine over a 3 main 2.25L engine unless you are planing on trying a turbo.
        The five main bearing 2.25L engine was only used between 1980 and 1985. In 1985 the 2.5L five main engine was introduced. This engine is basically a stroked 2.25L main engine with more bottom end torque. If the price was right I would go for a complete 2.5L petrol over a 2.25L petrol.
        The 2.5L was in production between 1985 and 1992 when the 200tdi was introduced. The 200tdi was such a superior engine that petrol four cylinder engines were discontinued.
        Zenith? They are good carbs. If it is in good condition I recommend keeping it if you are going for a standard remanufactured engine. If you are going for a performance remanufactured engine I suggest a B series Rochester.
        • PH4
          • 375
          Is now the time to consider maybe putting in a tdi? I never thought I would but in looking at costs might not be that much different. Is there a tdi that will drop stright in without having to cut or move radiator?
          Also, does anyone here have/had a Turner 2.25 and their experience?
          • n6zt
            • 21
            Also, consider the Robert Davis 3 litre engine. It is a wonderful replacement.
            • n6zt
              • 21
              Here is the link about the RD conversion.
              • ajones
                • Oct 2007
                • 35
                TeriAnn,
                Just curious but if someone had a 2.25 3 Main, would it be possible/feasible to stroke it by using the 2.5L connecting rods/crank, or would this be too much for the engine?
                thanks
                Alex Jones
                Atmore, Al
                '64 SIIA 88
                '79 MB 240D daily driver
                '80 MB 240D donor
                '59 MB 190D "rutso-ration in progress"
                '00 Chevy Silverado 4x4 "rescue vehicle"
                "Glad I ain't haze grey and underway!"
                • TeriAnn
                  • 1087
                  Originally posted by ajones
                  TeriAnn,
                  thanks
                  The 2.5L crank is a five main crank.
                  • TeriAnn
                    • 1087
                    The 200tdi will bolt to a 4 cyl Series bell housing, with a stud pulled. You can use the stock Series radiator if you don't use the turbo.
                    Here's an introductory web page:
                    The 300tdi had a different bell housing pattern and a different set of fit issues.
                    • ajones
                      • Oct 2007
                      • 35
                      Hmm I guess I deserve a dope slap for that one! What about the connecting rods? Are they any shorter thus allowing for slightly larger displacement?
                      Alex Jones
                      Atmore, Al
                      '64 SIIA 88
                      '80 MB 240D donor
                      • Jim-ME
                        • 1379
                        Although I really want a 2.5 NAD if I were (and I probably will) to stay with a petrol engine I would definitely get a 2.5 over the 2.25. British Pacific offers 2.25 performance engines although lists no prices. I'd be tempted to talk to them and see if they could build you a 2.5. I'll bet you could get one of the rebuilders/restorers to build you one if you can't find one any other way.
                        Jim
                        • leafsprung
                          • 1008
                          Rebuild
                          Any Machine shop worth a salt can rebuild your 2.25 to the same tolerances for far less than you would spend on any of these rebuilds . . .
                          • Jim-ME
                            • 1379
                            Good point! The rebuilds are simply a source of convienence and less down time. Do you feel the same about Series 2/2a transmissions and transfers?
                            Jim
                            • leafsprung
                              • 1008
                              A good local transmission shop can rebuild these very simple transmissions, however, a careful shadetree mechanic (ie the average enthusiast) can rebuild a rover transmission just as well. This isnt rocket science. You can pick up a core 2.25 or rover trans for almost nothing, rebuild them in your spare times and swap them in with little down time. Its cheap, its easy and you learn a ton about your rover in the process.
