You'd better have a pretty good plant to pull 4:10s in a 109.
Axle upgrade ideas
Just to give you some idea. The Series High range is 1.15:1 not 1:1 like most US transfer cases so when you figure out the effective R&P ratios with a number of different combinations here is what you get:
Standard high range1.15*R&P 4.7= 5.4
"" " " 1.15*R&P 4.10= 4.7
High Ratio T Case .87*R&P 4.7=4.09
" " " " .87*R&P 4.1= 3.57
So while you'll have higher gearing it won't be as bad as running around with a Ashcroft high ratio transfer case and 4.7 Diffs.
A strong 2.25 should be able to deal with it just fine, otherwise you can get plenty of other gear combinations for the Toyota axles- no shortage there.Comment
I am putting 96 disco axles under my 109, I got the axles for free, so I figured the conversion to disc brakes was worth it. I wil run the 3.54's for a while, they work fine with my 200 tdi and hi ratio transfer case.Comment
what are you doing for the steering setup?Originally posted by CliftonRoverI am putting 96 disco axles under my 109, I got the axles for free, so I figured the conversion to disc brakes was worth it. I wil run the 3.54's for a while, they work fine with my 200 tdi and hi ratio transfer case.Comment
clifton.
good luck with that. your overall ratio with the ashcroft box and the 4.7 diffs should be about right. The 3.5 diffs will probably make it too high.
Originally posted by CliftonRoverI am putting 96 disco axles under my 109, I got the axles for free, so I figured the conversion to disc brakes was worth it. I wil run the 3.54's for a while, they work fine with my 200 tdi and hi ratio transfer case.A Land Rover would never turn up to collect an Oscar. It'd be far too busy doing something important, somewhere, for someone."
