Im running a brand new electric aftermarket guage and its say im at 230f and in the red.But when I take off the radiator cap and stick a meat thermometer in there its reads about 130f.My watepump is pumping good and I just did a flush of the entire system and its very clean-no clogs-so is 230 too hot?Im running a summer thermostat also.
is 230f too hot?
Originally posted by ctroverI got it hooked up to the original sender.So the only way I'll get a correct reading is if I replace my broken Land Rover temp guage ?Comment
Originally posted by ctroverI dont want a mechanical guage-
Thread adapters are available for British pipe to SAE threads on senders.
To answer your original question; Yes, 230F is too hot, but that's a moot point since you have already confirmed the water isn't 230F.Last edited by Terrys; 02-08-2008, 10:09 AM.Comment
Hang on a minute... You guys mean to say that your gages actually work?!?
You can tell it's running too hot if one of the following applies:- The truck starts pinging while not under load (and it is uncommon for your truck to ping)
- If your engine bay has that recently steam cleaned look, and you haven't in fact steam cleaned it...
- If you hear a boiling sound when you put your ear to the ground next to the truck.
well i went to the auto parts store and bought a thermocap(radiator cap with a temp guage on it)and its reads a steady 130f.Im running a 76c thermostat because I thought I was overheating.So alls well.Electric gauge was way off at 230!I live in ct.What should be my ideal coolant temp yearound?Comment
I do not know why you are not listening to the good advice you are getting. What brand of guage did you install? If you would answer the question then someone could tell you which sender to get and it would all work together, instead you go on to buy even more unnecessary parts?The Goat, 2.8 Daihatsu Td, '73 coil conversionComment
Originally posted by KevinNYI do not know why you are not listening to the good advice you are getting. What brand of guage did you install? If you would answer the question then someone could tell you which sender to get and it would all work together, instead you go on to buy even more unnecessary parts?
I live in CT and am embarassed.Comment
My 2a with a S3 radiator mechanical temp gauge and a 82 degree C thermostat runs 170 to 180 this time of year with a radiator muff on that is completely closed. Not sure what temp it will run in the summer. I may have to change out thermostats.
JimComment
