High Back Seats
  • pepe
    • Nov 2007
    • 16
    High Back Seats
    anyone know of a good source of high back seats for an SIIa?
    Thanks
    Erik
  • Mercedesrover
    • 343
    Trakkers. Tough to beat for the money.
    jim
    www.seriestrek.com
    • leafsprung
      • 1008
      tough on your hind end too!
      • pepe
        • Nov 2007
        • 16
        am i really looking at 400$ for a pair? is there a cheaper way? used is fine with me.
        • yorker
          • 1635
          Volvo 240 seats. You can get them heated too if you want.
          Land Rover UK Forums
          • greenmeanie
            • 1358
            Jeep seats. Common as much used. I bought new Bestop Trailpro's. A simple adapeter consisting of a sheet of metal to span the Land Rover Seat rails plus a couple of lengths of 3/4" square tube and they fit a treat. It even lifts the back of the seat just enough to clear rear flange of the seat box so you get an extra 1 - 1.5" of leg room. They are also quite comfy.
            Cheers
            Gregor
            • Terrys
              • May 2007
              • 1382
              I put a pair of Corbeau GTS2 in my 110. They are less than Trackers, and more comfortable. I prefer the high side bolsters of the GTS2 but they have many styles.
              • Tim Smith
                • 1504
                I've got a set of RRC front seats to put in the lightweight and will be picking up a full set for the 5 door (if I ever get around to that project). Dry fitting shows that it should be easy with the exception of all those silly wires under there.
                Any one have a wiring diagram for early 90's Range Rover Classic seats?
                Another thing to remember, if you've got under seat fillers, is how you are going to get access to them once the new seats are in. Don't ask me how I know this.
                • greenmeanie
                  • 1358
                  A hole saw should help. It would also be a quite convenient mod to save embarrassment on those long runs with strong coffee and few rest stops.
                  • Tim Smith
                    • 1504
                    That would require a bumper sticker. Which might help ward against tailgaters too!
                    Here is something along similar lines for the trail rig that has everything (that you'd want).
                    Courtesy of http://www.bumperdumper.com
                    Oh dear, here goes another string down the toilet...
                    • scatterling
                      • 183
                      Anyone have any good suggestions for a two piece seat for exactly this reason. I have tanks under both seats and would like a more comfortable seat than the military one currently in the truck.
                      Neil Hanekom
                      '73 LHD 88
                      '99 D1
                      • Tim Smith
                        • 1504
                        Install the seats on a locking hinge of sorts. Luckily you've got a bulkhead (or bar behind you) and the seat belt in front of you so making sure the seat is 100% solid in a collision shouldn't be too much of a problem.
                        Of course there might be a seat option that works better than this idea...
                        • leafsprung
                          • 1008
                          Tracks I made for corbeaus. They remove in about 15 sec for access to the underseat compartments.
                          • One4adventure
                            • Feb 2008
                            • 5
                            Seats
                            Here are the disco seats I put in my 88"
                            • scatterling
                              • 183
                              Thanks Ike, would I then need to take the whole seat out to fill gas? ....I don't get enough weird looks as it is, filling gas inside the car, without having both front seats sitting on the ground beside the pump!
                              Neil Hanekom
                              '73 LHD 88
                              '99 D1
