Explain this to me: Timing Conversion Kit
  • NC Rover
    • Dec 2007
    • 288
    Previous owner gave me a box of unused parts with the Rover. One included this 2.25 Petrol Timing Conversion Kit.
    Can anyone explain the benefits of installing this or what it actually does?
    Thanks ahead of time
  • Mercedesrover
    • 343
    Holy crap, Zues makes gears for a 2.25 Rover? Too funny!!
    What they do is eliminate the timing chain. Noisy but useful on high horsepower engines. No stretch, no breakage.
    But really, timing gears in a Rover???? I wouldn't bother.
    jim
    www.seriestrek.com
    • pvkd
      • Jan 2007
      • 118
      Zeus timing gear eliminate the timing belt or in the case of the 2.25 engine the time chain. Chains break very rarely but belts on TDi engines have been know to fail.
      Personally I see little benefit on an engine with a timing chain like you 2.25 4 pot.
      Paul
      1995 LWB Range Rover Classic
      2001 P38A Range Rover
      • thixon
        • 909
        Like the others, I'm a bit surprised to see this product. Seems like overkill for a rover.
        Anyway, if you install it, the benefits are as follows: No deviation in timing that can be caused by a worn out or stretched timing chain, no chain to break, and the ability to brag about your gear driven timing in your rover.
        The downside is that a gear driven timing set ups are usually loud as hell. They generally make a high pitched whining sound.
        Gear driven timing is usually used in hotrod motors. Most guys I know don't like the noise.
        Hell, ebay it. I'm sure you'll get something for it.
        Travis
        '66 IIa 88
        • leafsprung
          • 1008
          I had a truck with this kit. It wasnt too noisey. Sell it to someone that HAS to have it.
          • KingSlug
            • 177
            Wasn't there an issue with the questionable materials used in the Zeus kits? I seem to remember Turner and Zues in a big pissing match over the whole thing.
            Visit The Wandering Hippo (my 109 S2A Ambulance).
            • Eric W S
              • 609
              Zues has made those for some time now. Google them. Couple of batches were not properly heat treated that led to premature failure.
              EwS
              • yorker
                • 1635
                Years ago(1990's) I almost bought a "souped up" 2.25 diesel that had this installed. Seems to me it was like in '98 or so. Some guy in the Missouri or somewhere like that had it for sale for $800. He'd pulled the engine for a 2.5 diesel IIRC.
                The Zeuss timing kit he had added to the 2.25 for added reliability. I often wondered where that 2.25 ended up.
                Land Rover UK Forums
                • yorker
                  • 1635
                  It is retrofitted to a lot of hotrods however timing gears were stock on a lot of the older I-6s and 4s. IIRC the Iron Duke 4 used them, GM I-6s, Ford 300 I6- they weren't real noisy in those applications.
                  A lot of those engines had an enviable reputation for longevity.
                  • NC Rover
                    • Dec 2007
                    • 288
                    Thanks for all the great input. I seriously doubt I'll be cracking open the 2.5 to do an install like this anytime soon. I'll probably just end up selling it to someone who actually needs it. I was just curious as I have a big box of parts and this was one of the bigger ticket items.
                    • yorker
                      • 1635
                      Put it on eBay- someone will want it.
                      FWIW I had one 88" that I purchased that had died and been abandoned for 15 years or so. When I took it apart I found that the pad that the chain wins on had come loose and gotten stuck in the sprocket for the cam- it bound up and sheared the end off the cam. Sort of an odd failure and one a kit like this might prevent. However a failure like that is pretty odd IMHO.
                      • thixon
                        • 909
                        Whats the deal with synthetic oils voiding the warranty (see his photo)? Am I missing something?
                        Travis
                        '66 IIa 88
                        • jp-
                          • 981
                          I has to have it.
                          How much NC?
                          67 IIA 109" NADA Wagon (sold)
                          • Donnie
                            • Apr 2007
                            • 287
                            The 300 cid Ford used composite gears on the cam on most of their applications. They were not known for lasting long, but were quiet. The replacment aluminum gear was a "singer" but a little noise is a Concern?
