Driveline (Propeller Shaft) Options
  • Erin
    • 19
    Hey Folks,
    Has any one fit a Disco II front driveline to the rear of a Series 88"? I have a salisbury rearend and the u-joints give a noticible hum when I am accelerating between 25 and 30 mph. I tried putting shims under the axel and it helped reduce the vibration but it did not entirely eliminate the vibration. I figured a DC drive line, like on the front of the Disco II, would help solve the problem since it is a CV rather than a single u joint. I figure the diff end of the shaft will fit a series salisbury but I am not so confident that the DC end will mate up with the output from my t-case. Is there anyone who has done this swap? Are there better options for DC drivelines? Should I just deal with the vibration and replace my u-joints every other year? Any help is appreciated.
    Thanks,
    Erin
  • KevinNY
    • 484
    Go here and read the tech section, it should help you figure it out.
    Trail Tested, Competition Proven, Show Quality Driveshafts and Slip Yoke Eliminators for Jeep Wranglers, Cherokees, Ford Broncos and more.
