Low Sulphur Diesel Fuel
  • Jim-ME
    • 1379
    What if anything will the new diesel blend do to older diesel engines or Rover diesels. Anybody have an idea or want to hazzard a guess?
    Jim
  • Mercedesrover
    • 343
    You should be running a fuel treatment in any diesel built more then five years ago. I like Lucas Fuel Treatment myself. Powerservice make a good one too.
    www.seriestrek.com
    • Jim-ME
      • 1379
      Jim,
      If I get a 2.5 NA Rover engine that is newly rebuilt does the need for additives still reply? What does sulphur do anyway?
      Jim
      • Mercedesrover
        • 343
        As I understand it, the process that reduces sulfer content also reduced lubricating properties in the fuel. The biggest problem is wear and failure to the fuel and injection pump in early diesels. Additives prevent this. I would think the sulfer also has something to do with cushioning the valve seats as in early petrol engines, but to tell you the truth I'm not sure about that. Modern diesel fuel also tends to have a lower cetain value than it used to. The Powerservice stuff boosts cetain a few points. (Cetain in diesel is like octain in gasoline.)
        jim
        www.seriestrek.com
        • yorker
          • 1635
          Originally posted by Jim-ME
          Jim,
          Jim
          It isn't the engine that needs the sulphur- it is the injection pump. All the LR injection pumps are designed to lubricate with their own fuel supply rather than the engine's oil. They aren't tolerant of other viscosity fuels either like SVO.
          Use an additive- 2-5% of bio-diesel would do the trick. Some people use el cheapo 2 cycle oil- You could probably use any number of oils- even 90wt(plenty of sulphur there!) Some work better than others.
          read this:
          The following are the preliminary results of a research study on diesel fuel Lubricity Additives. There is likely to be further commentary and explanation added at a future time. PURPOSE: The purpose of this research was to determine the ability of multiple diesel fuel additives to...
          Land Rover UK Forums
