Shifter Boot Question (pics)
  • NC Rover
    • Dec 2007
    • 288
    Would you consider this a RHD shifter boot? I was told it wouldn't make a difference but it looks as if the boot is pointing towards the passenger side. Think this will matter?
    [IMG]
    http://i32.photobucket.com/albums/d49/W8kbrder/Land%20Rover/Shifter0boot01.jpg[/IMG]
  • Eric W S
    • 609
    Shouldn't matter as long as the boot is in good condition.
    Worst case dial up our hosts and order another for a LHD D-90.
    • Bostonian1976
      • 750
      what transmission do you have?
      • NC Rover
        • Dec 2007
        • 288
        According to the previous owner, it was the LT77 Tranny w/ R230 xfer case...however I've been told by others it was the LT230 xfer case. I'm not familiar enough with the two to really tell a difference. I'm a noob...still working on that.
        • sven
          • 174
          Its an Lt230 transfer case.
          99 D1
          73 Series III 88"
          95 RRC LWB
          • NC Rover
            • Dec 2007
            • 288
            That sounds about right.
