got my belgium series 3 4x2 home today
  • autoguy
    • Oct 2007
    • 220
    well i bought the 4x2 Ex belgium military 88 that series 3 was local, the guy delivered it today
    now the fun starts
    it was 24 volt and has been converted to 12 with a delco alternator and the proper coil and distributor
    it has the zenith carb on it that i think i need to fiddle with, my 88 has a miss and no power but it does run and idle, the exhaust smells gassy so i am thinking i either have an air/vacuum leek or the carb is tuned too rich, but i have not had time today or the energy to fiddle with it
    i am going to get the interior cleaned out tomorrow
    stupid question, is there a trick to getting the internal passenger door lock to actually lock, i tried pushing the button/knob on the door above the handle in and i locked as long as i was holding the button in, but as soon as i released the button it was unlocked
    we now have two rovers sitting in our driveway, dads disco series 2 and my series 3 mom is thinking about getting a disco series 2 when her jaguar is payed off too
    i have heard it said that an old vehicle chooses its new owner, well mine locked me in as soon as i shut the door when i looked at it saturday, so i told my 88 that as long as the frame was good and it started and ran than i could have a new home in my driveway and i would be its new owner/care taker, well it sits in my driveway now
    i know some people here are curious as to how the transfer case and front axle look on the 4x2 and i will get picts taken tomorrow as long as its not raining (the weather guessing people are talking rain though)
    i have the front axle, drive shaft and transfer case to convert my 88 to 4x4 and when it gets warm i will get that done, the guy i bought my rover from is going to ship the two levers i need the hi/lo lever and the yellow knobbed 4wd lever/stick the ground is too cold to swap the axle and transfer case now
    thank you again to all the people here who helped guide me in my decision to buy my rover, thank you for all your advice and opinions and steering me away from a couple of rovers
    i am home now and DSL is a very good thing i was using dial up at my grandma,s
  • Hormel
    • 44
    Never a stupid question. Did you try twisting the knob after pushing it in? Least that's the way on the series IIs. Some might ask why lock...
    Welcome to spending a lot of time under the hood or on your back.
    John
    • autoguy
      • Oct 2007
      • 220
      John
      thanks, i tried twisting the knob a bit but i might not have gotten it twisted far enough, i will try again monday
      the hilarious part about me locking the rover is that the drivers door lock, locks with a screwdriver, the ignition key does not fit the lock hole, so it could easily be unlocked with a screwdriver
      i figure if i lock my rover that it will deter said thief for a few seconds and i can grab a gun or let my boxer loose after said thief, the boxer is crotch trained
      • LaneRover
        • 1743
        Originally posted by [B
        the boxer is crotch trained[/B]
        Just pray that the Boxer never gets confused when attacking!
        • autoguy
          • Oct 2007
          • 220
          LOL I would be inside if I let him after said thief
          on a serious note, right now the battery is dead in my rover and the gas is shut off and it has a miss, it has a zenith carb
          I will upload the Picts I took on the way home of my 88 on the trailer, Monday afternoon
          • sayers
            • 126
            Lets see some pic's good luck with your project !
            • Tim Smith
              • 1504
              Never a stupid question when you're asking on this board!
              When my SIII door locks go up but won't stay, it usually means that the door isn't locked all the way. Give her a good slam and see if that helps. Put your weight into it.
              Also with, my truck, when the doors start to need a good slam I usually take that as a sign to add a drop of oil to the lock mechanisms. Seriously! Take some time (an afternoon) to put a few drops of 3-in-1 oil to all of the little moving parts in the truck. You'll find that it does wonders for making the doors, shifters, peddles, cables and everything else work as they should.
              It's good therapy for the truck and yourself.
              By the way, I still say your money was better invested on those Rolex's. Although you should find that owning a series rover is, in fact, priceless.
              Cheers,
              Tim
              • ducttape
                • 175
                Aren't pictures required for all new purchases?
                1967 Series IIA 88
                • autoguy
                  • Oct 2007
                  • 220
                  Tim Smith, thanks i will either use 3 in 1 or brake free gun oil, i have some militec gun oil too that is slicker than snot, i might use it
                  my 88 also came with the 24V starter and generator, which are both heavy by the way
                  ducttape and sayers, mmm pictures i will get more picts taken this afternoon, and will get the picts uploaded from my iphone that i took on the trip home with my 88 on the trailer ride home
                  i need to think up a name for my rover too
                  picts from the previous owner
                  • Tim Smith
                    • 1504
                    Name for the rover eh?
                    Hmm, I can't help but notice the name of that vapor barrier on the garage in the back ground.
                    Just a thought.
                    Take care,
                    Tim
                    • autoguy
                      • Oct 2007
                      • 220
                      Just a thought.
                      Take care,
                      Tim
                      thanks for pointing it out, thats hilarious and ironic, green guard might work for a name
                      • autoguy
                        • Oct 2007
                        • 220
                        got my passenger door lock working, gave it a shot of liquid wrench and worked it a bit, thanks for the tip, Tim Smith
                        where is the chassis number located at on the chassis ?, not the one on the bulkhead but the number on the frame, or is it the vin number ?
                        • highmile
                          • Nov 2007
                          • 93
                          the VIN number should be stamped on the front right frame horn just behind the bumper.
                          Former owner of 1967 Series IIA 109 NADA
                          1996 Land Rover Discovery SE7
                          1995 Range Rover Classic SWB
                          • autoguy
                            • Oct 2007
                            • 220
                            thanks i will go look soon
                            • ducttape
                              • 175
                              Ok, it might take a trained eye to notice, but that is a thing of beauty
                              David
                              1967 Series IIA 88
